Originally Posted By: ajalowsky
Tuesday!
Originally Posted By: rcooke
Roy Cooke Sr.
Originally Posted By: jpope
Jeff Pope
JPI Home Inspection Service
“At JPI, we’ll help you look better”
(661) 212-0738
jpope wrote: |
I agree as it is worded. If you think of it as three fuses, there's an answer that would work. . . |
Roy Cooke Sr.
http://Royshomeinspection.com
Originally Posted By: jwilliams4
“not just an inspection, but an education”
Originally Posted By: Aimee Jalowsky
Roy Cooke Sr.
bking wrote: |
True Roy but the question pertains to " when you do see one in residential" It may happen and HI's need to know the possibilities. |
Roy Cooke Sr.
Jeff Pope
(661) 212-0738
bking wrote: |
The question never stated that all three poles had wires present. Nothing wrong with using 2 poles of the 3 as long as the rating was correct etc. |
Roy Cooke Sr.
rcooke wrote: |
Years ago they used to fuse the neutral but not any longer. |
Jeff Pope
(661) 212-0738
pdickerson wrote: |
Mine too. I am still waiting for someone to explain why a 3-pole breaker is indicative of a subpanel.
Roy, I don't understand why a 3P panel installed as you described is cause for immediate replacement. Sure it hokey, but is there any code violation? Is it dangerous? |
Roy Cooke Sr.
Originally Posted By: kelliott
Quote: |
How on earth is a three pole breaker indicative of a "sub" panel? Picture please |
kelliott wrote: |
I wonder...The question says "disconnect" not breaker. |
kelliott wrote: |
If we're talking just an old-style 3 pole pull handle disconnect, it would have to have a "sub" panel with fuses or breakers. |
Jeff Pope
(661) 212-0738
rcooke wrote: | ||
Wrong it was designed for industry 3 phase system . I did a home that had a 3 phase 120/208 volt panel in it. It had 120/240 volts single phase coming into the home . The panel had only 2/3 of the breakers in it as the other 1/3 was not able to be used. Again wrong requires immediate upgrade to proper panel. Years ago they used to fuse the neutral but not any longer. |
Roy Cooke Sr.
