two water heaters/ one flue
Originally Posted By: m bettencourt
Two water heaters mounted side by side in attic. 3" flues from each heater connect with one roof penetration. I wasn’t there, but should the minimum flue be 5" where they are joined? (100% plus 50%)
Also, I was skimming through "Mastering the Profession 4th edition" and on page 276, ninth paragraph under natural gas-venting, it says that "Two 90 degree elbows are permitted in a vent system......" I thought that G2427.6.4 "Offsets" states that you can't exceed 60 degrees. What is the discrepancy? Thanks.
Originally Posted By: dvalley
A pic would be fantastic.
David Valley
MAB Member
http://www.masscertified.com
I wasn’t there, but I am just curious about the requirement for joining two flues together (3" B-vent) from the water heaters. Should they need to be greater than 4 1/2 inches and can they just join in wye of some sort? Also wanted info on the other question I had. Thanks.
I am looking for some guidance on the difference between sections G2427.6.4 which speaks of gas offsets a 2428.2.3 which seems to cover the same thing but allows two 90s. In my example of two side by side gas water heaters and a common vent, which code would apply?
