I inspected a house that was built in 1961. Attached are the pictures of the wiring in the sub-panel where the air handler shutoff switch was located. Can anyone guess what type of wiring this is? It seems like it is a braided aluminum but I just want to get the second opinion. I am curious about what orange-colored grease is as well. Thank you.
Aluminum with anti-oxident compound.
Thank you.
Exactly…no problem with either.
Thank you, David and Larry.
Not to be a nit picker (OK maybe) but the term is ‘stranded’ aluminum wire (as opposed to solid). Braided wire looks like a girls hair braid (as in an auto or equipment ground strap).
Did you happen to observe the wire size & amperage rating.
I’m gonna guess & say 150A on 2/0 al.
Judging from the red stripe on the black conductor I would guess that this alumimum SE cable. As Bob stated it is correctly called a stranded coductor.
Time to hit the NACHI Books on electrical stuff. It’s free by the way…
This photo was taken at the air handler shutoff panel. The wire size was #2 or #4 stranded AL for 50 amp circuit breaker.
The service entrance cable was 1/0, supplying power to 150 amp main disconnect circuit breaker.
