Just did an inspection and found a foundation post that looks like a wooden barrel. Is this an older style that was used in older homes or is this something that was just wedged in there. I should note that there were other inappropriate foundation posts in this house such as wooden legs for tables and 2x6s which is why I am obviously concerned about this type. Thanks in advance!
Well, it’s better than CMU blocks that we normally see stacked the wrong way.
Were the barrels filled with concrete?
Yes they were filled with concrete
Beats building forms, I guess.
Any footing visible?
That Botton barrel looks almost big enough for a footing, depending on the load… ![]()
I didn’t see any footings. Just dirt around it and the rest was covered with that vapor barrier
Appears to be empty barrels used as forms. The wider bottom barrel a wood distillers cask.
The top thinner barrel a metal or plastic drum.
Due to the circumference of the bottom column a footing may not be required.
I believe that was already indicated.
Since you have other TEMPORARY supports and will be recommending review and correction by a competent foundation contractor WHY worry over 1 more. Get on with it
