Very Rusty Electrical Equipment!
Found in a basement under the streets of Buffalo, NY where the salt has caused this corrosion:
This is currently being replaced with new equipment.
NEC Section 300.6 is a good read, check it out!
Originally Posted By: aslimack
Can’t ya just tape it?
Adam, A Plus
Originally Posted By: bking
www.BAKingHomeInspections.com
Hey Bruce:
Where can I get the calendar image that shows the date I saw on your page here:
http://www.bakinghomeinspections.com/Cost_for_Inspection.html
Thanks! ![icon_lol.gif](upload://zEgbBCXRskkCTwEux7Bi20ZySza.gif)
Joe Tedesco, NEC Consultant
www.nachi.org/tedescobook.htm
Joe,
I do a lot of old homes in the Buff, so to speak. What street was that one on.
Adam, A Plus
Adam:
I believe it was located downtown in one of the commercial properties.
One of my students gave me a few images during our show and tell discussions when I was in Buffalo a few weeks ago.
Do you look for any items that fall within this subject? ![icon_question.gif](upload://t2zemjDOQRADd4xSC3xOot86t0m.gif)
Quote:
300.6 Protection Against Corrosion.
Metal raceways, cable trays, cablebus, auxiliary gutters, cable armor, boxes, cable sheathing, cabinets, elbows, couplings, fittings, supports, and support hardware shall be of materials suitable for the environment in which they are to be installed.
Section 300.6 applies generally. For specific applications, see the particular article covering the appropriate cables, raceways, or enclosures.
(A) General. Ferrous raceways, cable trays, cablebus, auxiliary gutters, cable armor, boxes, cable sheathing, cabinets, metal elbows, couplings, fittings, supports, and support hardware shall be suitably protected against corrosion inside and outside (except threads at joints) by a coating of approved corrosion-resistant material such as zinc, cadmium, or enamel. Where protected from corrosion solely by enamel, they shall not be used outdoors or in wet locations as described in 300.6(C). Where boxes or cabinets have an approved system of organic coatings and are marked ?Raintight,? ?Rainproof,? or ?Outdoor Type,? they shall be permitted outdoors. Where corrosion protection is necessary and the conduit is threaded in the field, the threads shall be coated with an approved electrically conductive, corrosion-resistant compound.
Zinc chromate paste is one type of electrically conductive compound that could be approved.
Yeah Joe,
I look for it and put it in the report. I spent as many as 8-10 hours on a few of the reports for some of those properties. Grueling.
The detail i try to include in my reports goes far to drive me nuts when i have some of those 100 plus year old homes you have depicted in your photo.
I didn't know you were in town that recently. I would have tried to make it but i've been buried with work, more or less, since mid February. Most days i'm even eating on my lap in front of the computer or while driving. I'll look for you next time around. Any idea when that might be? (Roughly)
Adam, A Plus
Joe,
the calendar on my site is a feature within Webstudio 4.0 that uses javascript to keep the image updated with the current date.
here is the html, good luck. In webstudio it is just a drag and drop thing that is really easy.
<DIV ID="SGROBJ7D4C41E10301B2031" STYLE=" position:absolute; top:972px; left:19px; width:234px; height:60px; z-index:8;">
<IMG SRC="Cost_for_Inspection/IMAG006.JPG" WIDTH=234 HEIGHT=60 BORDER=0>
</DIV>
<DIV ID="HTMOBJ7D4C619E20101A50" STYLE=" position:absolute; top:1545px; left:309px; width:229px; height:181px; z-index:9;">
<SCRIPT LANGUAGE="JavaScript">
function montharr(m0, m1, m2, m3, m4, m5, m6, m7, m8, m9, m10, m11)
this[0] = m0;
this[1] = m1;
this[2] = m2;
this[3] = m3;
this[4] = m4;
this[5] = m5;
this[6] = m6;
this[7] = m7;
this[8] = m8;
this[9] = m9;
this[10] = m10;
this[11] = m11;
function calendar()
var monthNames = "JanFebMarAprMayJunJulAugSepOctNovDec";
var today = new Date();
var thisDay;
var monthDays = new montharr(31, 28, 31, 30, 31, 30, 31, 31, 30,
31, 30, 31);
year = today.getYear();
if (year <= 200)
year += 1900;
thisDay = today.getDate();
if (((year % 4 == 0) && (year % 100 != 0)) || (year % 400 == 0))
monthDays[1] = 29;
nDays = monthDays[today.getMonth()];
firstDay = today;
firstDay.setDate(1); // works fine for most systems
testMe = firstDay.getDate();
if (testMe == 2)
firstDay.setDate(0);
startDay = firstDay.getDay();
document.writeln("<CENTER>");
document.write("<TABLE BORDER='1' BGCOLOR=White>");
document.write("<TR><TH COLSPAN=7>");
document.write(monthNames.substring(today.getMonth() * 3,
(today.getMonth() + 1) * 3));
document.write(". ");
document.write(year);
document.write("<TR><TH>Sun<TH>Mon<TH>Tue<TH>Wed<TH>Thu<TH>Fri<TH>Sat");
document.write("<TR>");
column = 0;
for (i=0; i<startDay; i++)
document.write("<TD>");
column++;
for (i=1; i<=nDays; i++)
if (i == thisDay)
document.write("<FONT COLOR=\"#FF0000\">")
document.write(i);
if (i == thisDay)
document.write("</FONT>")
column++;
if (column == 7)
column = 0;
document.write("</TABLE>");
document.writeln("</CENTER>");
calendar();
</SCRIPT>
</DIV>
<DIV ID="SGROBJ7D510101333A2611" STYLE=" position:absolute; top:80px; left:39px; width:200px; height:133px; z-index:10;">
<IMG SRC="Cost_for_Inspection/IMAG007.JPG" WIDTH=200 HEIGHT=133 BORDER=0>
</DIV>
</BODY>
</HTML>
Adam:
Not for a while, probably when it is snowing again!
Bruce:
Thanks, I will try it out.
![icon_smile.gif](upload://b6iczyK1ETUUqRUc4PAkX83GF2O.gif)
Thats ok Joe,
It'll be easier to get around the work schedule then.
Adam, A Plus
Originally Posted By: bkelly1
http://www.nachi.org/bbsystem/usrimages/I/IM000083.JPG ]
[ Image: http://www.nachi.org/bbsystem/usrimages/I/IM000080.JPG ]
Both taken in cancun, mexico
Thanks Ben!
Great shots of some common hazards. I have some images from Tijuana that look the same. ![icon_rolleyes.gif](upload://iqxt7ABYC2TEBomNkCmZARIrQr6.gif)
I would like to see more if you have the time.
