I was reviewing a plumbers evaluation and he mentioned that the washing machine drain had a “below the floor trap”. He didn’t specify if it was an issue, but I don’t know why else he would have mentioned it. (the entire line is 1 1/2" and not vented so he wants to replace the entire line).
Is a washing machine drain ‘below the floor’ trap an issue (as long as the standpipe is the proper height)?
It is, and that’s why he is recommending replacement of the entire line. His report mentioned the below floor drain, but did not deal with a repair specific to the trap because the entire line is going to be replaced anyway.
Due to the lack of responses, I assume (I know;) ) there is no issue with a below the floor trap.
After sleeping on it, I think the plumber may have mentioned the below the floor trap because of a comment in the home inspection report that a trap was not noted. (difficult access)
</IMG>
