Walking on shingles can void a warranty
I know we’re not required to walk on a roof for an inspection, but we CAN. But when I had my roof replaced a couple years ago, they told me that they can void my warranty if I walk on it. Obviously, it’s my roof and if I need to get up there, I will. But what if the installing contractor is next door and sees us on “their” roof, and they void the warranty? Has anyone ever come across this? I doubt it would actually happen, but what if…
No.
It sounds like a contractor that does not want anyone checking their work.
First off what State are you in? Just as a side note in Texas we are required to walk the roof if it can safely be done.
Secondly the only warranty the contractor can “void” is his own labor warranty. Here in Texas there is an implied one year warranty on craftsmanship which is the contractor’s work itself and not the product. Does your State force any such warranty? If so I would suspect it is no more than a year and obviously ended already.
The shingles themselves are warranted by the manufacturer. I have not seen any manufacturer warranty that has language to void a warranty just by walking on it as long as the walking is not damaging it. The manufacturer can void the warranty for improper installation by the contractor.
It sounds as if you have a roofing contractor that either has a “God Complex” or is afraid you might identify inferior work.
Also as a frame of reference I do walk my own roof as necessary and do perform minor repairs. Of course I document the before and after in the event there are warranty questions by anyone. If the roofing material has been properly installed I have no worries about warranties being honored if needed.
I suppose you could void the warranty if you cause damage to the shingles by walking on them. But that would be unusual. Don’t walk on it when it is 110 degrees out, don’t walk on it with your golfing spikes, don’t walk on the ridge caps, etc, etc, etc.
I’m in Md. I was shocked when I heard that, and I immediately googled it, and sure enough, google said it’s a thing. I was just curious if anyone else had ever run into that before, or had that topic come up in an inspection.
Are they going to bring in a forensics team to differentiate if it was you that walked on the roof or the half dozen workers that installed it?
I would love to see them float above it while it was being installed. Walking on a roof doesn’t void the shingle warranty. And a roofers workmanship warranty isn’t worth the paper it’s written on.
Never ran into that before. As for during an inspection the owner, or builder on a new home, is free to tell me I can not walk on the roof and I will not. Of course it will be noted in the report that occurred and the potential for missed issues that might occur.
As for walking the roof I would highly recommend that as you walk it you are taking high resolution images of all surfaces prior to walking on them. Storage is cheap but a BS claim is not and the high resolution images can help prevent a claim that you damaged the roof.
