Water Heater Pan retro kit?
A client of mine noticed the water heater had no pan. It was in an unfinished basement, so didn't seem like too much a big deal. However, the distance from the wh to the floor drain concerned him. Is there a way to install a pan after the wh is already installed? Like some dam to hose setup? Maybe a quick product?
thanks,
tom
A sheet metal shop could fabricate a pan with one side bent down that could be slipped under the tank.
Get them to make me one too. :p
John Kogel
www.allsafehome.ca
[quote="jkogel, post:2, topic:36761"]
John Kogel
www.allsafehome.ca
[/quote]
Brilliant answer, and simple too. :D
[/QUOTE]
I like the idea. I can send you a DIY kit, a sheet of aluminum foil, all the the low-low price of $99.99!
Thank you,
tom
