I have a client that called and says his water heater pilot wont stay lit. They suspect its due to the gas furnace when it starts since they are installed right by each other. Is it common for this to happen or does it have to do with the burner being dirty or the thermocouple going out?
It’s pretty classic for a marginal thermocouple. When the furnace fires off, the gas pressure may dip just enough to take the output from a marginal thermocouple below the threshold to keep the gas valve on. For the 6 dollars they cost, I’d replace it anyhow just to not have to consider it in my troubleshooting process, and it will probably solve the matter too. A thermocouple is a regular PM part for a water heater, almost like replacing the furnace filter or the brakes on your car.
They have had the water heater for about 6 years so I would imagine its the thermocouple going out because the pilot started going out a few days ago. I would think this would rule out the possibility of the furnace causing the pilot to go out.
as a licensed home inspector we are not qualified to recommend specific repairs unless we also hold a license for that trade.
do so at your own expense and possibly jeopardize your livelihood
i’d advise qualified seasonal servicing of both units (HVAC & WH) as there are possibly other issues present that we or they are not aware of…
I just suggested it, didn’t repair it . Where i come from a gas fitter do the installation not plumbers Here Plumbers do the the gas work . I used to work on everything from a wall heater to Boilers you could stand in the fire box.
I too recommend a license contractor do any work on systems. I also recommend serve every year which i have never seen down here just doesn’t happen
