Hi Folks,
I just inspected a home today and the TPR valve configuration looks a little bit weird. Do you think this is violation of the code?
Thanks for any comments
Max
Hi Folks,
Max
Yes, refer it to a plumber. No valve or multiple terminations or traps allowed(with valve closed water is potentially trapped) and the length is too short.
While I know it’s wrong, unfortunately I see similar setups here 90% of the time (even on new construction). I still write it up.
Thanks for all of your comments. The pipe actually lead to a discharge point outside. I guess it is still wrong when it has so many joints on the pipe?
It can be a bomb/missile waiting to happen…:shock:![]()
It cannot run uphill, it traps water.
As others have said, it is incorrect. I suspect an easy fix, would be to relocate the valve to the top of the unit, if there is a provision, and then the existing pipe to the exterior could be used.
Why in the heck did they do it that way ?
a lot of extras there for on reason .
Robert ask the next time you see it in new construction.
Yes needs immediate repair
[FONT=Verdana]http://www.nachi.org/tpr-valves-discharge-piping.htm](http://www.nachi.org/tpr-valves-discharge-piping.htm)[/FONT]
[FONT=Verdana]No way can you be too critical with a water heater .
They can destroy the home and kill
http://www.youtube.com/watch?v=BZEIqG2RrMs](http://www.youtube.com/watch?v=BZEIqG2RrMs)
http://www.youtube.com/watch?v=9bU-I2ZiML0](http://www.youtube.com/watch?v=9bU-I2ZiML0)
http://www.combustionsafety.com/secured/pdf/safetyalerts/star_spencer_lesson.pdf
[/FONT]
Roy
On you own heater do you test the valve periodically ?
I do.
Have not so I took your advice and it worked great 3 year old tank just did not shut off slow drip .
,Finally got It to stop hope you sleep well tonight you got me a good one .
Haha ! Oh Hell !
My report .
Upon arriving at the Cooke Home I discover Mr. Cooke running frantically around his H2O heater.
I appears as this owner could not shut off the TPR valve.
After further evaluation we discovered he in fact Mr. Cooke was a Home Inspector and knew better that to mess with the darn thing.
Mr. Cooke informed this inspector that he was told by a reliable source that testing the TPR on occasion was the proper thing to do.
I informed Mr. Cooke to not believe everything he heard on these so call professional forums because professionalism was lacking highly there at the present time. .
We recommend a full psychological examination by a state licensed professional .
And to get a qualified plumber out there to fix the darn thing before he screws the whole darn thing up.
:D:D
Roy Lewis
1st Pro Home Inspection.
I’m sorry Roy
I just couldn’t help myself !
Exactly what I deserved ,
Thanks you made my morning ,Caught me when I was still asleep .
Great life more should enjoy it like you ,I, and a few others do.
Uh Oh !
I’m headed to the ignore list now !![]()
Have a great day Brother.
Roy L.
