Water Heater
Originally Posted By: gbell
http://www.nachi.org/bbsystem/usrimages/P/P2140041.JPG ]
[ Image: http://www.nachi.org/bbsystem/usrimages/P/P2140040.JPG ]
Cold water supply connected to the TPRV drain line. There is a regulator in the middle.
I have never seen this. Anyone familiar with it?
Thanks
Greg Bell
Bell Inspection Service
I don’t see the regulator in the middle. Could it be a pressure relief valve for excess pressure in the cold water supply.
Did you see the termination point for the TPRV. I once found one that "harry homeowner" had connected somewhat similar to this and then ran the TPRV termination to a supply valve in the "handyman" sink in the garage so he could wash his tools and himself.
Erby Crofutt
B4U Close Home Inspections
Georgetown, Kentucky
www.b4uclose.com
Originally Posted By: ckratzer
It seems very weird and I’ve never seen anything like it and can’t think of a reason for it.
I also can’t keep from commenting on the installation.It looks like someone got a PEX crimping tool for christmas and just had to use it.The fittings alone probably cost about thirty $'s.It would have been easier and less costly in this case to finish it out in copper.
I will add ,however and totally off the subject, PEX is great for remodel jobs in tight places that you can’t get to with a torch.
Cheremie
Originally Posted By: wcottrell
Greg,
Some municipalities require small expansion tanks on the cold water inlet to handle expansion in the system since backflow or check valves are required at the street connection. Conbraco make a expansion valve that allows excess pressure to be discharged, but they usually require separate lines to the exterior. My best guess.
Regards Bill
Originally Posted By: Jay Moge
Greg, aren’t expansion tanks for hot water heating systems, i’ve not yet seen one on a potable water system. icon_redface.gif
Originally Posted By: rmoore
Jay Moge wrote:
Greg, aren't expansion tanks for hot water heating systems, i've not yet seen one on a potable water system. ![icon_redface.gif](upload://f7DX2EWhmUfsDapWaYT3oJHMCj1.gif)
Must be a regional thing then Jay. Every newer home here has one at the water tank, and I'd say about 50% of newer replacement tanks are also fitted with them. Recent "code" says you have to have one if there is any type of check-valve at the supply.
I have no idea what Greg's set-up is doing though.
Richard Moore
Rest Assured Inspection Services
Seattle, WA
www.rainspect.com
Greg…
I blew it up and lightened it. Looks like a Watts 530C calibrated pressure relief valve? http://www.wattsreg.com/pdf/1910868.pdf
Can't be right to share the TPR discharge line though. You wouldn't know what was leaking!
Richard Moore
Seattle, WA
www.rainspect.com
http://www.nachi.org/bbsystem/usrimages/P/P2140042.JPG ]
This heater is on the second floor. That is another reason that it doesn't look correct.
Here is a picture of the expansion tank that you are speaking of.
[ Image: http://www.nachi.org/bbsystem/usrimages/P/P2150013.JPG ]
Greg Bell
http://www.nachi.org/bbsystem/usrimages/P/P2150014.JPG ]
Greg Bell
gbell wrote:
The discharge tube stopped about 2-3 feet once started behind the heater.
Unless you count a big wet patch on the first floor ceiling as a "visible termination" that would be also be very wrong. ![icon_wink.gif](upload://ssT9V5t45yjlgXqiFRXL04eXtqw.gif)
Richard Moore
Seattle, WA
www.rainspect.com
Greg,
There should be a check valve on the cold water supply if they are using a recirculation pump and an aquastat wired in the electrical line to the recirculation pump. I’ll admit this is the first time I’ve seen a plumber return the recirc. hot water to the drain, usually come in below check valve on cold water inlet.
Regards Bill
Originally Posted By: dandersen
Looks like a Christmas tree!
There is more stuff on there than we have down at the hardware store!!
You put all that compression stuff on and then you have to spend a fortune to regulate the water pressure.
Can't anyone solder copper any more!
And they still can't get hot water to the bath?
