Water pressure test 75 psi at the outside faucet where the house cutoff
is located…right by front entry door…Ran all faucets and baths on the inside
house and flushed toilets…did not notice anything abnormal.
Plumber did come out to the house to upgrade water heater. Installed a
TPR pipe, earthrquake straps and a pan. Water heater was located inside
house in a closet.
The buyers been in the house for a week. She saying water pressure is
low…and really gets effected if water is running in more than one place at
the same time.
Did you check for functional flow during the inspection? In my states, we are required to. Generally, that means running the shower and flushing the toilet at the same time. If there is no reduction at the shower, then that is considered functional.
Imagination? - had one like that in Connecticut last year. She would take showers at the gym that had a big, no restriction shower head. Just not the same at home.
Not enough info. is it public or private? street or well? Average for neighborhood? Size of that PVC? GPM? Air bladder? How long will it hold pressure when off? Pressure at street or well? Volume? It can have good pressure all day long and still have reduced volume. What size pipe inside house?
