Series #1
Should I try to get big $$$ from the Antique shop?:mrgreen:
Thanks in advance if anyone can help.
Series #1
Cant help with that one Bob.
Here’s their contact info: http://www.weil-mclain.com/en/contact-us.aspx
Whats a boiler???:mrgreen::mrgreen:
The ‘original’ “intended purpose” for your “still”. ![]()
Wow, series # 1…cool
They only list the year on these. Second and third number of the serial number
Should be another plate on the side of the boiler with the serial #
Not always. I had a Series #3 a few months ago. No plates or marks where one may have been anywhere else (full access 3ft around). Never did arrive at an answer to that one. If I remember right, it was reference dated late 1930’s. (Didn’t have the Weil-McLain contact info back then).
I’m going to say 1932.
Hmmm sounds crazy but the home is a 1925 brick bungalow.
may be time to replace.
Just i thought Bob it looks more like late 50’s early 60’s just from the style.
Any serial numbers on the burner?
Have another coffee and read #8.
I’d give Weil-McLain a buzz, and see if they can help
Pre-60’s. I’m gonna say 1955. BTW- The CP numbers started in '77.
I see someone piss in your corn flakes BTW i said burner not the unit, That’s the part where the flame is lololol Just teasing
I have a Weil-Mclain Co. water heater for my radiant heat. the water pressure stays at 0 and is not heating the floors. any ideas on whats wrong? it is Series #2 model G-8.
Thank You
Circulator pump not working?
Either that or no water, blockage,etc.Could be a lot of things but why not just call the HVAC guy?
Honestly would not try to fix it unless my neighbor with trade skills came over to lend a hand.
Forum advice does not always translate to skills.
Good advice
