Panelized systems simply installed on top of drywall and then covered in insulation could certainly pose a fire risk however, most of what is installed around here is actual cable installed on the finish side of drywall which then becomes embedded in the plaster finish coats. These systems are no more a fire hazard than wiring inside wall cavities.
I don’t want to see inexperienced inspectors looking foolish by unnecessarily flagging every electrical radiant ceiling heat system as a fire hazard.
Wayne I ran it across the ceiling and was even able to figure out which way the coils were running ,plus found the dead spots.
I learned that it very costly to go in there and repair and that it is an older system.
I doubt they would be updating the insulation in places that still have it unless they are also switching to new heating methods.
Going through all my old inspection pictures this week to file them so will post a few here over the next couple days.
Very easy to miss this system if you have not seen it before.
Was not able to see any heat strips my camera must have been on the Fritz;-)
These systems are nothing like the new ones. They are old systems that run off 220V - 20 amp
I refuse to accept the fact that any aged electric heat, especially stranded wire that gets hot enough to produce heat, could truly be safe and functional after 40 years of use.
I find most has failed long ago and usually does not work properly now anyway.
Any aged wall or ceiling heat always gets a recommendation to have it evaluated to ensure it is safe for functional use. The fact still remains that due to the age, it is inefficent source energy…
Google car seats catching fire. Same concept…
It can ‘happen’.
Maybe some of these other brand threads have some insight ?
About 369,000 results (0.15 seconds)
Search Results
Honda Pilot Driver’s Seat Catches Fire - Car Forums - Edmunds
10 posts - 7 authors - Last post: Dec 4, 2007
Turned off the heated seat, blew out the fire (luckily) and scooped out melted foam with my fingers. The car reeks! …
townhall-talk.edmunds.com/direct/view/.f117d51/0 - Cached - Similar
2008 Mercedes-Benz GL450 Reliable? - Jan 10, 2011
Heated Seats Not Working On 2009 Mazda 5 - Nov 30, 2010
More results from townhall-talk.edmunds.com »
Get more discussion results
Burn Alert Electric Heated Car Seats Danger | Bachus & Schanker
The National Traffic Safety Association (NHTSA) received complaints as early as 2001 of heated car seats catching on fire; The car manufacturers do not post …
http://www.gminsidenews.com/forums/f…seats-car.html - Cached - Similar
VWVortex.com - To Those Who Have Had Heated Seats Catch Fire
35 posts - 27 authors - Last post: Nov 19, 2003
Recently, I have noticed a number of 'texers speaking of a minor flaw involving the heated seats of VW’s Cold Weather Package- a flaw that …
forums.vwvortex.com/showthread.php?1113071 - Cached
Heated Seats - Heated Seat FAQ’s - Car Seat Heaters - Check …
CAN THEY CATCH THE SEAT ON FIRE? HOW HOT DO THEY GET? HOW LONG DOES IT TAKE FOR BEFORE ONE CAN FEEL THE HEAT? DO SEAT HEATERS HAVE THERMOSTATS BUILT INTO …
www.checkcorp.com/seat-heater/products_faqs.asp - Cached - Similar
Heated seat fire 2001 T&C
7 posts - 3 authors - Last post: Jan 2, 2008
madfire: I have a 2001 Town and Country and in Feb. 07 my passenger seat caught on fire while my son was sitting in it.
forum.chryslerminivan.net/.../7031-Heated-seat-fire-2001-T-amp-C - Cached
Intro and info on broken heated seats - 3 posts - Dec 4, 2010
Heated seat problem - 4 posts - Jan 13, 2008
More results from forum.chryslerminivan.net »
heated seats - butts on fire - MBWorld.org Forums
2 posts - 2 authors - Last post: Oct 15, 2010
All, Recently bought a 2004 W209 CLK55. The heated seat button on the dash when pressed does not light up red as per the owners manual.
http://www.gminsidenews.com/forums/f…utts-fire.html - Cached
Heated Seat Fire (x-post from VWVortex) - Passat World Forums
19 posts - 12 authors - Last post: Dec 4, 2003
Seems that this lady’s heated seat caught fire. Can’t say that I recall ever hearing this before on Club . FYI. …
http://www.passatworld.com/forums/sh…d.php?t=130965 - Cached
Mercedes-Benz Complaints - Failed Heated Seat Causing Fire
Dec 18, 2009 … My best friend has A mercedez benz s.u.v. her heated seat caught on fire today 3-16-10 catching her coat on fire and burning A hole in her …
http://www.complaintsboard.com/compl…z-c290928.html - Cached
Volvo heated seats caught fire - Honest John - Telegraph
Jul 1, 2010 … Honest John hears from a reader whose Volvo’s heated seats caught on fire.
http://www.gminsidenews.com/forums/f…nest-John.html - Add to iGoogle
My heated seat caught fire!!! - Toyota Tundra Forums : Tundra …
Oct 22, 2010 … I have a 2007 Tundra Crew Max. After I bought it new, I had Red Rock Katzkin leather put in the front and rear seats. Had heated and cooled …
http://www.gminsidenews.com/forums/f…t-caught-fire/ - Cached
2002 E46 330ci Cabriolet - * Heated Seat Fire * - BMW Forum …
10 posts - 5 authors - Last post: Dec 18, 2008
2002 E46 330ci Cabriolet - * Heated Seat Fire * BMW 3 Series Forum - Technical Talk on the BMW E46.
http://www.gminsidenews.com/forums/f…at-fire-t6517/ - Cached
Asses of Fire: Jeep Heated Seat Recall
Jun 12, 2006 … If anybody ever got too into Black Flag, one might’ve listened to the second side of My War or searched out the Nig Heist’s record, …
jalopnik.com/180132/asses-of-fire-jeep-heated-seat-recall - Cached
Have your heated seats caught fire? JGC Recall - JeepForum.com
Heated seats can catch fire in the 2003/ 2004 Jeep Grand Cherokee Sport. The recall will be sent out in 2-3 weeks.
http://www.gminsidenews.com/forums/f…recall-282643/ - Cached
14
Mazda’s Heated Seats Work A little Too Well | Mazda in the News
Mar 3, 2010 - … and potentially could set fire to the seat according to the National Highway … Luckily, by moving swiftly to resolve the heated seat issue, Mazda will …
http://www.mazdainthenews.com/mazdas…ttle-too-well/ - Cached
“From tech stocks to high gas prices, Goldman Sachs has engineered every major market manipulation since the Great Depression — and they’re about to do it again.”
“The world’s most powerful investment bank is a great vampire squid wrapped around the face of humanity, relentlessly jamming its blood funnel into anything that smells like money.”
"If America is circling the drain, Goldman Sachs has found a way to be that drain — " Matt Taibbi
Yeah, and Skylab could fall out of the sky!!! :shock::p;-)
I belive it did
**Nation: Skylab's Spectacular Death**
Monday, Jul. 23, 1979
Read more: http://www.time.com/time/magazine/article/0,9171,947058,00.html#ixzz1KpcS5bm3
Yes, I know. Perhaps I should have added “… and fall on your house”.
The paranoia of todays Society is unreal.
Hey Sean, you better not fall asleep at night… the Boogey-Man might get ya’ !!! :mrgreen:
Besides… whatever happened to the (ignorant) HI’s favorite line… “well it’s been that way for 40 years, so it is fine”.
Yeah, I thought so! Only applies to other inspectors work. :roll:
It can ‘happen’.
Search Results
14
Yeah, we all heard you the first time. :mrgreen:
No, I didn’t bother reading through all of Society’s BS “spilled coffee in my lap, now I’m gonna sue you” crap. :twisted:
I started skimming through your post and got to here, before stopping…
If that doesn’t scream **BS **I don’t know what does!!! :roll:
All’s good.
Just yanking your chain a bit.
Apples to oranges…
There’s a difference in heating elements being surrounded by flammable materials and heating elements encased in plaster.
New ones wouldn’t be a problem , we talking about the 70’s here . BTW scan with a camera you probably find were it is broken . found several . I will make a comment on any of these from that time period.
Radiant Heat Ceilinngs
always a bad idea in this part of PA.
I have found a few (very small number).
Almost all were inoperable in some area of the home.
Replacement of the Heating / HVAC system of the Home was recommended.
never a question or complaint.
OK guys,next time I get one in a 100 unit complex with everyone using ceil heat I will instantly tell them to yank it all out and run an entirely new heating system or they will all die.
Yep.
Your correct Bob Most that we find here are not in use, NEW systems in how ever hardly no one disconnects the ceiling heat here. They add insulation and move on That’s where the problem comes in . similar to knob and tube. then some kid cranks the thermostat and walks away.
Sub me for it
If I conclude same response.
Wayne do you suggest your client should be demanding money for the expense of removal and install of a totally new system?
If so ,what (Facts) are you using to base this on other than here say?
Bob,
No one uses the systems anymore. It would cost a fortune to operate.
