I know it is not from an exhaust fan - it is same new duct work as i saw near the furnace.
I don’t think it was incomplete job.
I am guessing it may be some kind of air intake for the new furnace that they put in the attic. Like a way to get take up air. A way to balance pressure in the home maybe?
does that make sense?
can anyone help me out here?
Update: I took a photo of the ductwork installers phone number and i’m going to call them to get the exact answer.
Yes Bob,
There is a stove and range hood in basement.
The furnace is not high efficiency, the furnace room is not sealed - no door , and I don’t have pics from down there.
I see it was part of the new ducting system, but what is the purpose?
maybe it is incomplete work?
Would it make sense to get make up air from an attic space? not to me!
ON SECOND THOUGHT,* if it is combustion air and being burned up, then it doesn’t matter if there is insulation dust in it, However, maybe over a long period of time that maybe leave some kinda residue in furnace?
Starting to lean towards it being a combustion air source- makes more sense because in winter, the attic should be as cold as outdoors, and as long as roof is ventilated well its all good.
The combustion air doesn’t go directly into the furnace. It’s just a raceway for fresh air to enter into the room that the furnace is in. It won’t be ‘burned’ up. So if indeed it is for combustion, it will be pulling cold air and debris from the attic into an open room. Was there a register/grill up on the wall inside the room?
