If this is a sub panel, I see no meter on the exterior of the entire building what so ever. This is a condo unit built in 1974. This panel also does not look like a split bus panel. I did not remove the panel cover because the paint was laid on really thick an didnt want to cut the wall. I know its not much to go on, but what are your thoughts?
I cut every caulked or painted panel cover loose. The electrician that comes behind you needs to if he’s going to followup. At least document it as a defect if you can’t open it.
Thats my fear. Tearing the wallpaper or leaving cut marks where they aren’t supposed to be. And then, the time it takes to do it. What is the best method?
Exactly why I don’t ever cut panel covers off/loose!!
dmelton1
(Daniel W. Melton, Mississippi License # 0663)
15
I cut every cover loose regardless. Would you want to pay for an inspection on your house to an inspector who never looked at the inside of the panel? Oh I suppose it’s ok to have #8 main conductors for a 200 amp panel. Slap me with a splintered ruler.
