I am wondering what type of siding this is or what it is called. It is not metal or vinyl. It appears to be some sort of wood/paper stuff. Yes and I know it is moisture damaged, just want to know what to call it. Do not see it here much Anyone have a clue. Thanks
Hardboard siding is made from a mixture of wood fibers, wax and resin. These materials are heat-treated and pressed together to form panels that resemble wood, giving them a uniform appearance of wood without the defects such as knots or raised grain. The composite wood product can be manufactured to resemble traditional, crafted siding elements for a lower cost than real wood. Today’s hardboard siding is engineered with improved termite and moisture resistance.
Best place I’ve found to identify specific siding is: http://www.sidingsolutions.com/pages/sidingid.htm
(Note: some of the links on that website are no longer valid but most are and the photos help a lot as well)
Most homeowners don’t think they have a problem, because they haven’t taken the time – or don’t know how – to properly examine their hardboard siding.
Qualifying damage may not be visible to the untrained eye, and many homeowners are unfamiliar with the court-approved damage protocols and inspection procedures. Without a professional evaluation, you could miss your opportunity to receive a fair settlement.
ClaimSource One has identified and evaluated more than 75,000 properties over the last five years and found that most had some type of qualifying damage. We can help you start the claim process today with a brief inspection that takes less than 15-20 minutes.
Some of these photos are shown in very advanced stages of deterioration. Your hardboard siding does not have to look as bad as the photo examples in order to qualify for compensation.
Take the time to review this checklist. If you answer “yes” to one or more of these questions – or are unsure about any of them, call ClaimSource One and let one of our trained inspectors evaluate your property.
