Skinny plumbers only…LOL
better than most you see?
TPT discharge inside the cabinet? A bit grainy. That’ll be exciting…
Data plate not visible
I’d like to see it on a pedestal, but there’s that shelf above it
A pan would be nice
Draining it will be a pain
It took me a minute… I opened the closet door and something didn’t look right… first I thought someone peeled the labels off, then I realized someone installed a new electric water heater backwards. elements, thermostats, drain everything You need to get to up against the back wall of the closet. The sad part is every single connection was flex type and no modifications needed to be made to install it properly…just when You think You can’t be surprised on an inspection good old uncle give me another beer shows up…
Makes me wonder if hot and cold were piped reverse. Dyslexic plumber.
I seriously don’t believe there was a plumber involved in this installation Martin…
Yup Home Depot weekend warrior.
