I observed in the sub that all the ground wires where not atached on a grounding bar in the panel. They are just looped back at entry and was wondering where do you think they are attached two.
I recommended a sparky. The garage was another handyman/extension cord special.
As for the grounding…I see several ground wires at the top portion of this LSE but I don’t see what they’re bonded to. It appears that they are routed back outside the panel. They are bent back and are going right back outside of this panel.
Somethings wrong here.
Where do those grounds go after they leave the panel?
hmmm…are they pulling them all back out the panel and twisting them together and taking one to the GE…I SURE HOPE NOT…geesshhhh…anyway this is a no brainer…refer…refer…refer…scratch head…refer…refer…
Now as an electrician…I am gonna say…Mr. Bad Grounds…I need to get in the area above this panel…Meet my little friend…sheetrock saw…
Frankly I just want to see above the panel at that they are trying to do…
Ahh…but in the true nature of the beast…I would want to get into the wall and see those grounds before I worry about double taps and openings…lol…the grounds are by far the main issue.
Since it’s a sub-panel, then there should be isolated neutrals and grounds. Looks like the electrician didn’t have a separate ground bar to install in the panel, and just connected all the grounds to the box … :roll: … and I am assuming the same thing happens at the feeder to the sub-panel, where the ground is also just connected to the box.
Whether it’s 14-3 or 12-3 wire, it’s a good question. There are 13 hot wires, but only 8 neutral wires at the sub-panel.
Looks to be five 120V circuits (hot and neutral), one pure 240V circuit (2 hots on a 2-pole breaker), one 240V/120V circuit (2 hots on a 2-pole breaker and a neutral), and two (2) circuits that are either 240V/120V or multi-wire circuits (two hots and a neutral).
The last two circuits mentioned (where you see both a red and black wire going to individual single pole breakers, and I assume a neutral wire to the neutral bar) may be multi-wire circuits that feed two separate 120V circuits with a shared neutral … which is okay sometimes as long as it’s wired correctly and there is a handle tie to shut down both breakers simultaneously … or could have just been wired wrong or there may be an overloaded neutral. Either way a sparky is needed for repairs.
