Originally Posted By: rwashington This post was automatically imported from our archived forum.
Look for the words “maximum input”. It is sometimes tricky to locate among all the small font on the spec sheet. Finding that spec sheet is also tricky. They put that thing on the underside ceiling when you pull the cover off. I end up twisting my neck in some crazed fashion. Wish I had a picture for ya’ll.
the capacity by the amount of burners.
Generally, in residential units, the output is between 20K and 25K per burner. A two-burner unit (like the one pictured) can be estimated at 40K to 50K. A five-burner unit can be estimated at 100K to 125K.
-- Jeff Pope
JPI Home Inspection Service
(661) 212-0738
