Who was here first, Electrician or Plumber!
Joe Tedesco, NEC Consultant
www.nachi.org/tedescobook.htm
Originally Posted By: chorne
Originally Posted By: lkage
“I have never met a man so ignorant that I couldn’t learn something from him.”
Galileo Galilei
Originally Posted By: rcooke
| jtedesco wrote: |
How would a Home Inspectior address this situation? |
Roy Cooke Sr.
http://Royshomeinspection.com
Originally Posted By: phinsperger
| jtedesco wrote: |
Paul Hinsperger
Hinsperger Inspection Services
Chairman - NACHI Awards Committee
Place your Award Nominations
here !
Originally Posted By: gbeaumont
Gerry Beaumont
NACHI Education Committee
e-mail : education@nachi.org
NACHI phone 484-429-5466
Inspection Depot Education
gbeaumont@inspectiondepot.com
"Education is a journey, not a destination"
Originally Posted By: mcyr
Originally Posted By: cradan
Chris
http://www.inspect4me.com
Chicago Illinois Home Inspections
| mcyr wrote: |
This was't meant to be a theory, but a joke to this off the wall scenario. I can not stoop down my imagination that there are qualified? tradespeople out there that would do this type of work. You do not have to be a Home Inspector to see what's wrong with this scenario. Hopefully, the inspector wrote this up accordingly, and now that I mention it, how was it wrote up? Let me guess, and I am not trying to be sarcastic, The water heater has been installed in front of the electrical panel, depriving proper access to the panel. The electrical code, ( code section) states that 3 feet of clearance should be available in front of the panel. Wires above the panel should be attached properly to a minimum of 12" above the panel. The water heater should be installed in a proper environment to not impair the access to the electrical panel. The new water heater access should be installed in a location where a drain could be available for the temperature relief valve. Something like this could go on for a while. Marcel |
Roy Cooke Sr.
| mcyr wrote: |
Roy, what did you mean by this statement? (KISS keep it simple stupid) |
Roy Cooke Sr.
| mcyr wrote: |
I understood that part of it with no problem, it is the underlined word that bother me. I guess our ethics are a little mismatched and will leave at such. Thank you Marcel |
Roy Cooke Sr.
