amarkuson
(Andrew Markuson)
January 17, 2024, 2:08am
Hey guys, I have 2 questions on some of the wording below. Any pics would be great. I couldn’t find anything on google about it. Thanks!
What does blocked mean?
What would be the reason for it to be done?
“blocked no more than 1.5” of the truss/rafter”
labstein
(Les Abstein, CMI)
January 17, 2024, 2:16am
2
[quote=“Andrew Markuson, post:1, topic:238017, username:amarkuson”]
/quote[]
sfetty
(Dave Fetty, CMI)
January 17, 2024, 2:22am
3
It means that a shim(or block) should be installed.
dhorton2
(Daniel Horton, CMI®)
January 17, 2024, 2:25am
4
Here is an example of when one could be used. See how the strap is not installed right against the truss? They could nail a block between the strap and the truss to keep it tight. They dont want to see that strap more than 1.5" away from truss.
amarkuson
(Andrew Markuson)
January 17, 2024, 3:07am
5
Ok, so theoretically they could pull the clip off the truss. Nail a 2x4 piece on. Then reattach the clip to the 2x4? Would this be a way to fix the issue that the installation in the concrete was incorrect?
dhorton2
January 17, 2024, 3:38am
6
Actually, It’s not required to block it… it just says it CAN’T be blocked more than 1.5" away.
ddagostino
(Dominic DAgostino, CMI HI3957)
January 17, 2024, 1:18pm
7
They could just install a properly spaced RTW connector instead.
sfetty
(Dave Fetty, CMI)
January 17, 2024, 9:59pm
8
The Plans for many homes include instructions that if there is more than an 1/8" gap, that it should be shimmed or blocked.
amarkuson
(Andrew Markuson)
January 17, 2024, 10:41pm
9
Interesting. Good to know.
dhorton2
January 18, 2024, 12:01am
10
But we are talking about the wind mitigation report. There is no requirement in that report that anything must be blocked
