Window Swiggle gasket purging…
I’ve had a rash of this …this week.
And I’m at a loss for a proper narrative…Which doesn’t happen very often.
What is your narrative on this.
The home today every window was this way.
Thank very much in advance.
The seal(s) at the (location) window(s) appeared to be failing or failed. Reduced R-value, condensation and/or the windows view could become obstructed. We recommend repair and/or replacement of damaged windows.
Every job I check the seals because those without a metal strip over them like buckling in facing the south and west .
Start noticing that and you will find more issues than before .
