This thread is dedicated exclusively for those students currently enrolled in the InterNACHI course titled, “Wood-Destroying Organism Inspection Course” located at http://www.nachi.org/wdocourse.htm
Thank you.
Thank you.
This is from Chapter 17: Foundation Structures
*Figure 108. A structure with a floating slab and hollow concrete block foundation wall with arrows indicating potential termite entry points *
This is a picture of a supported slab repeated from Figure 106.
Thanks!
Found another error in Chapter 20: Basic Construction Terminology
fascia: horizontal boards attached to rafter/truss ends at the roof eaves and along gables. Gutters are typically attached to the fascia. Fascia boards are commonly attacked by carpenter bees.
Should be the *vertical *boards, or the gutters won’t catch the runoff very well:mrgreen:!
Thanks
The vertical update has been made. Waiting for researchers to decide about floating slab PIC.
Here’s InterNACHI’s definition of “fascia,” which is a term used in architecture to refer to a frieze or band running horizontally and situated vertically under the roof edge or which forms the outer surface of a cornice and is visible to an outside observer. This is to say that the long dimension of the surface is horizontal and the short dimension is vertical. Gutters are typically attached to the fascia. Fascia boards are commonly attacked by carpenter bees.
The “fascia” definition within the course has been returned to its original, with an update of the definition.
fascia: a term used in architecture to refer to a frieze or band running horizontally and situated vertically under the roof edge or which forms the outer surface of a cornice and is visible to an outside observer. This is to say that the long dimension of the surface is horizontal and the short dimension is vertical. Gutters are typically attached to the fascia. Fascia boards are commonly attacked by carpenter bees.
Chad,
Good catch. Thank you.
That was indeed simply a repeated illustration from a few paragraphs prior. A new illustration has been inserted (below).
Figure 108. A structure with a floating slab and hollow concrete block foundation wall with arrows indicating potential termite entry points (illustration courtesy of MSUE)
Thanks Ben, thanks Chad!
Termite tube on sill plate
When looking for signs of termite activity, the inspector must be alert to those conditions that favor termite infestation. The most critical condition is wood-to-soil contact.
Thanks Ben.
Maybe IAC2 should have a similar thread.
JMO.
I just finished the wdo course. Where can I find out if there is anything else I need to complete before I can do wdo inspections in pa.
In Iowa you have to be certified as a pesticide applicator in order to do Inspections.
I see on your states DNR website there is a pesticide applicators certification, you may want to start there.
Nice photo Ben. You have to know what you are looking at to understand the mud tub.
Hey guys,
Correct me if I am wrong, but the facia board is typically attached across the ends of the rafter tails and the gutter is then mounted onto the facia board. This would actually be in the horizontal position in that it runs parallel to the house at the lowest edge of the roof pitch. The downspouts from the gutter to the ground run vertically.
Thanks,
Gregg Spear
Spear Home Inspection, Inc.
InterNACHI member
Fascia: InterNACHI® - International Association of Certified Home Inspectors The board runs horizontally and is installed vertically…
Course definition of fascia has been edited. It now reads:
That sounds a little better. Yes?
Me again
Being new to this forum and actually posting something, I guess it is good to check the post dates before responding to them.
Thanks
Gregg
No problem, Gregg. Thanks for contributing.
Does a licensed inspector have to be a licensed applicator to complete form NPNA-33?
