I was trying to find @ruecker 's fairly recent post concerning writing certain things up that seem insignificant in the grand scheme of things but I don’t remember the name of the topic.
I’m about to publish a report for a seller pre-listing and I’m torn about writing this multiple-instance “not as designed” install up. It’s a red wire that is incorrectly wired into fixture/receptacle boxes that is only used to bond copper water supply piping. Bonding is our friend but its just not the way to do it properly.
The last photo under the kitchen sink is not very clear but the red wire is tapped into the outlet around the cover plate and attached/bonded to the copper water supply pipe next to it.
Would you write this up?
On a side note, I was concerned about the holes in the attic j-box potentially allowing sparks to exit the junction box holes that the red wires are attached through but the adjacent can light knockouts have screwdriver slots that are similar in size and large enough to allow sparks to escape as well. We often comment on missing j-box covers or knockouts but how small a hole or gap is even allowable? Down the rabbit hole I go
Edit: After posting this, I feel that there might be some other reason for this “bonding” or at least some info that might help in determining the reasoning…This is a 1958 home with ungrounded branch circuits. The majority of the outlets were ungrounded but there were a couple that did test as grounded and I pulled off a cover of one of the outlets and it had a ground wire appropriately connected. I did not observe a GEC at the Zinsco main panel’s factory neutral bus but did observe some ground wires attached to the bus. The last pictures show the neutral/ground bus in the main panel.
Maybe the above mentioned bonding is being used as a GEC for the couple/few outlets that tested positive for being grounded?
