What I like is at 12 feet I can tell if they used hanger nails or not .
I like this when I do not have to struggle over some of the bad stuff under the deck. My deck I cavered the bottom with sloped metal roofing and closed it in two 4 ft sliding doors.
It is always dry and a great place to store things
Sean, with places like that to inspect, it can be quite frustrating into trying to find some sort of defect when it looks like it came off an A/E drawing. :mrgreen:
Great point Marcel.
Air driven fasteners. Clipped head or round head nails.
UBC has code compliance.
Overdriven nails:
Cliped head nails.
I sold my clipped head gun.
I only hand drive fasteners but will rent on occasion.
Do not forget RAMSET that can be used for ledger boards then the hangers. INSTALL NAILS FLUSH TO THE SHEATHING
The 1994 UBC stated that the nail should “not fracture the surface of the sheathing”.
The 1997 UBC has clarified the language to state that the “head or crown of the nail is flush with the surface of the sheathing.”
Nails installed with their heads resting on but not into the sheathing can cause problems for roofing and other finishes.
Nails should be driven so that the top of the nail is flush and not above the surface of the sheathing.
What happens during an earthquake?
Nails will try to pull through the thickness of wood structural panel sheathing during an earthquake
For this reason, it is important that nails should be driven flush with the surface of the sheathing and not overdriven and that they be placed correctly
Overdriven nails:
Reduce the shear wall strength by effectively reducing the thickness of the sheathing.
At panel edges, overdriven nails allow easier nail punch-through.
At intermediate studs, overdriven nails allow easier panel buckling.
Why are nails overdriven?
Excessive air pressure in the nail gun
Too long of a driving pin on the nail gun.
When the spacing and framing member thickness allow, nails should be added to replace any overdriven nails.
