three phase…i will probably never run into it in residential is what im thinking… here is what i understood in ITA training. three phase simply has the typical 2 120 leads and then another which was referred to at the time as the ‘wild leg’…this arrangement is for certain loads that may run fine on 240 but they take a little extra ‘oomph’ to get them up to speed so that wild leg supplies whatever amount of additional help (could be varied amounts of extra voltage) to get things rolling, the needs of the load dictate how much extra voltage is drawn… and then it can rock and roll on just the 240. now thats the way i understood it, thats probably flawed in theory and maybe only part of the whole story but at least it made some sense…especially to a guy who will probably never encounter that. but i still love learning so ill be watching for feedback…right?, totally toast?, partially right?..whats the word
Completely, sorry dude. :roll:
Without going too deep into this, the wild leg or stinger is called this because it is 208 to ground vs the other 2 legs at 120 to ground. To see any additional power would require a single phase 208 equipment and this would be rare. It would be more beneficial to run the larger item as a 3 phase load.
- Vol. I - DC
- Vol. II - AC
- Vol. III - Semiconductors
- Vol. IV - Digital
- Vol. V - Reference
- Vol. VI - Experiments
- Worksheets
- Videos
- Forums
- Blogs
Search this site
Table of Contents:
Volume II - AC » POLYPHASE AC CIRCUITS »
Three-phase Y and Delta configurations
Initially we explored the idea of three-phase power systems by connecting three voltage sources together in what is commonly known as the “Y” (or “star”) configuration. This configuration of voltage sources is characterized by a common connection point joining one side of each source. (Figure below)
Three-phase “Y” connection has three voltage sources connected to a common point.
If we draw a circuit showing each voltage source to be a coil of wire (alternator or transformer winding) and do some slight rearranging, the “Y” configuration becomes more obvious in Figure below.
Three-phase, four-wire “Y” connection uses a “common” fourth wire.
The three conductors leading away from the voltage sources (windings) toward a load are typically called lines, while the windings themselves are typically called phases. In a Y-connected system, there may or may not (Figure below) be a neutral wire attached at the junction point in the middle, although it certainly helps alleviate potential problems should one element of a three-phase load fail open, as discussed earlier.
Three-phase, three-wire “Y” connection does not use the neutral wire.
When we measure voltage and current in three-phase systems, we need to be specific as to where we’re measuring. Line voltage refers to the amount of voltage measured between any two line conductors in a balanced three-phase system. With the above circuit, the line voltage is roughly 208 volts. Phase voltage refers to the voltage measured across any one component (source winding or load impedance) in a balanced three-phase source or load. For the circuit shown above, the phase voltage is 120 volts. The terms line current and phase current follow the same logic: the former referring to current through any one line conductor, and the latter to current through any one component.
Y-connected sources and loads always have line voltages greater than phase voltages, and line currents equal to phase currents. If the Y-connected source or load is balanced, the line voltage will be equal to the phase voltage times the square root of 3:
However, the “Y” configuration is not the only valid one for connecting three-phase voltage source or load elements together. Another configuration is known as the “Delta,” for its geometric resemblance to the Greek letter of the same name (Δ). Take close notice of the polarity for each winding in Figure below.
*Three-phase, three-wire Δ connection has no common. *
At first glance it seems as though three voltage sources like this would create a short-circuit, electrons flowing around the triangle with nothing but the internal impedance of the windings to hold them back. Due to the phase angles of these three voltage sources, however, this is not the case.
One quick check of this is to use Kirchhoff’s Voltage Law to see if the three voltages around the loop add up to zero. If they do, then there will be no voltage available to push current around and around that loop, and consequently there will be no circulating current. Starting with the top winding and progressing counter-clockwise, our KVL expression looks something like this:
Indeed, if we add these three vector quantities together, they do add up to zero. Another way to verify the fact that these three voltage sources can be connected together in a loop without resulting in circulating currents is to open up the loop at one junction point and calculate voltage across the break: (Figure below)
Voltage across open Δ should be zero.
Starting with the right winding (120 V ∠ 120o) and progressing counter-clockwise, our KVL equation looks like this:
Sure enough, there will be zero voltage across the break, telling us that no current will circulate within the triangular loop of windings when that connection is made complete.
Having established that a Δ-connected three-phase voltage source will not burn itself to a crisp due to circulating currents, we turn to its practical use as a source of power in three-phase circuits. Because each pair of line conductors is connected directly across a single winding in a Δ circuit, the line voltage will be equal to the phase voltage. Conversely, because each line conductor attaches at a node between two windings, the line current will be the vector sum of the two joining phase currents. Not surprisingly, the resulting equations for a Δ configuration are as follows:
Let’s see how this works in an example circuit: (Figure below)
The load on the Δ source is wired in a Δ.
With each load resistance receiving 120 volts from its respective phase winding at the source, the current in each phase of this circuit will be 83.33 amps:
So each line current in this three-phase power system is equal to 144.34 amps, which is substantially more than the line currents in the Y-connected system we looked at earlier. One might wonder if we’ve lost all the advantages of three-phase power here, given the fact that we have such greater conductor currents, necessitating thicker, more costly wire. The answer is no. Although this circuit would require three number 1 gage copper conductors (at 1000 feet of distance between source and load this equates to a little over 750 pounds of copper for the whole system), it is still less than the 1000+ pounds of copper required for a single-phase system delivering the same power (30 kW) at the same voltage (120 volts conductor-to-conductor).
One distinct advantage of a Δ-connected system is its lack of a neutral wire. With a Y-connected system, a neutral wire was needed in case one of the phase loads were to fail open (or be turned off), in order to keep the phase voltages at the load from changing. This is not necessary (or even possible!) in a Δ-connected circuit. With each load phase element directly connected across a respective source phase winding, the phase voltage will be constant regardless of open failures in the load elements.
Perhaps the greatest advantage of the Δ-connected source is its fault tolerance. It is possible for one of the windings in a Δ-connected three-phase source to fail open (Figure below) without affecting load voltage or current!
Even with a source winding failure, the line voltage is still 120 V, and load phase voltage is still 120 V. The only difference is extra current in the remaining functional source windings.
The only consequence of a source winding failing open for a Δ-connected source is increased phase current in the remaining windings. Compare this fault tolerance with a Y-connected system suffering an open source winding in Figure below.
Open “Y” source winding halves the voltage on two loads of a Δ connected load.
With a Δ-connected load, two of the resistances suffer reduced voltage while one remains at the original line voltage, 208. A Y-connected load suffers an even worse fate (Figure below) with the same winding failure in a Y-connected source
Open source winding of a “Y-Y” system halves the voltage on two loads, and looses one load entirely.
In this case, two load resistances suffer reduced voltage while the third loses supply voltage completely! For this reason, Δ-connected sources are preferred for reliability. However, if dual voltages are needed (e.g. 120/208) or preferred for lower line currents, Y-connected systems are the configuration of choice.
- REVIEW:
- The conductors connected to the three points of a three-phase source or load are called lines.
- The three components comprising a three-phase source or load are called phases.
- Line voltage is the voltage measured between any two lines in a three-phase circuit.
- Phase voltage is the voltage measured across a single component in a three-phase source or load.
- Line current is the current through any one line between a three-phase source and load.
- Phase current is the current through any one component comprising a three-phase source or load.
- In balanced “Y” circuits, line voltage is equal to phase voltage times the square root of 3, while line current is equal to phase current.
- In balanced Δ circuits, line voltage is equal to phase voltage, while line current is equal to phase current times the square root of 3.
- Δ-connected three-phase voltage sources give greater reliability in the event of winding failure than Y-connected sources. However, Y-connected sources can deliver the same amount of power with less line current than Δ-connected sources.
Discuss this topic | Feedback «Previous Page](http://www.allaboutcircuits.com/vol_2/chpt_10/4.html) | Next Page»
- Published under the terms and conditions of the Design Science License
Sitemap Disclaimer Contact
I don’t know if I would call a single phase 208 volt load rare. They’re used all of the time. I think what Jim meant is that using a 208 volt single phase load from a 120/240 volt, 4-wire, Delta system would be rare. On reason is because your standard single pole breakers used in those panels are limited to 125 volts to ground. So for all intents and purposes the high leg by itself is useless.
was that greek or martian?
Because of that I was going to suggest making this a new thread just involving 3 phase power.
That is kind of where I was going. I guesss trying to keep it simple I might have left too much out.
Thanks for the help.
I posted the question about moving on to 3 phase because of the complexity of the systems. I have never totally understood it except to know I should reccommend or hire an electrician to examine the three phase aspects of installations I have had to inspect. It was intended as a joke but also to educate. Thanks guys I think you well illustrated the point I intended to make.
You’re right, it is more complicated than a single phase, 120/240 system which the reason I suggested someone start a new thread about just 3 phase. I’m not an engineer but I have been dealing with 3 phase systems regularly for almost 25 years so I can probably provide some insight in layman’s terms if anyone is interested.
I see this is fairly old thread. But i’ve been asking this no nuetral question lately. The reason why i ask i understand the answers givin here and i can buy into the center tap answer. But why does a 220 dryer have a neutral? why would it not work the same? I used to work in residential new construction and ran alot of 10-3 which is 3 conductors and a ground 2 hots 1 nuetral and 1 ground. So why is there a neutral on dryer but not a/c?
The dryer has 120 volt equipment. In most dryers the heating element is 240 volts but the motor that turns the tub is a 120 volt motor.
Then we have the light and buzzer and some 120 volt timers
Mike gave you a good explanation. There is nothing stopping a manufacturer from making a dryer that can run on straight 240 volts.
If ITA told you any of those things, they should be ashamed of themselves. There are two basic configurations for three-phase, Delta and Wye. The primary and secondary can be different from one another. For example, it is common to have a Delta primary and a Wye secondary.
You may hear someone refer to a system simply as being Delta or Wye. In such instances, the terms Delta and Wye refer to the secondary. The complete description would include both the primary and secondary such as Delta-Wye, Delta-Delta and so on. The description will usually include the ground connection on grounded Deltas. They will be referred to as Corner-grounded or Center-tapped.
Wye is more popular than Delta because of its versatility. Delta is often used where there are many large loads. It is easy to derive subsystems that are different from the main system. For example, manufacturing plants often have Delta systems but have derived Wye systems for certain areas such as offices.
If you have any questions about poly-phase systems, feel free to ask.
George,
All High leg Delta transformers will have one winding that is center tapped and it will have a high leg. A corner grounded delta will have one of the phases grounded. The main will have two fuses although it is a three phase system.
What most residential dwelling will have is a single 240 volt transformer (just one phase) that is tapped in the center to have the lower voltages of 120. This transformer will be neither a wye or a delta.
Mike,
That’s right. I should have said that it is center-tapped Delta that has a high leg. Also, I meant to say that center-tapped Delta and corner-grounded Delta are relatively rare. However, I should qualify that statement by saying that they are relatively rare in the geographical areas with which I am familiar. They may be more common in some areas than others.
I did not intend to imply that three-phase is common in residential. Residential is usually split single-phase (one transformer, center-tapped). I apologize for any confusion.
Hope I am not asking something that was raised but I did not see how the power company keeps the two legs of a 240 circuit perfectly in diametric phases? Also, is this done at the transformer or the generator?
It would be at the transformer not the generator which generates much higher voltage. 240 volts from the transformer is a single coil.
They don’t.
