I have a ? I went with a friend on a service call for air condition, anyway
he explain to me when he hooked up volt meter from air handler red to yellow
which is power to cool anyway he touched his meter to red to yellow and it read 24volts then says to me it is open at 24volts and when switch is closed
it is asking for cool and it reads zero because it is the same wire and there is
no difference . WHAT!! what is difference ,well i dont get it cause if the swith is on then shouldn’t it say 24volts he says i have it backwards . when you hook up to a outlet it reads 120 and that means you have power .i am confused can someone out there explain this better to me to understand? to me what i am getting is that when a swithc is on it should read voltage and read zero when it is off thanks. you HS are great people
RV
