Two questions with this one. 1. Is there any issue with the trap arrangement? I’ve seen this scenario where they are all run together and then trap. 1 trap for all three.
2. What is some terminology for the drain line being sloped the wrong way? It all flows away from the drain.
A single trap shall be permitted to serve two or three like fixtures limited to kitchen sinks, laundry tubs and lavatories. Such fixtures shall be adjacent to each other and located in the same room with a continuous waste arrangement. The trap shall be installed at the center fixture where three such fixtures are installed. Common trapped fixture outlets shall not be more than 30 inches (762 mm) apart.
