I’ve not seen a trap set up quite like this…any thoughts?
Thanks in Advance!
Not allowed by the Uniform Code.
Because of three traps to one drain?
Multiple traps on one trap-arm (the horizontal portion connected to the vertical drain line) is specifically prohibited by the UPC.
Three drains served by a single trap and trap-arm is what the UPC requires. The IRC, however, allows multiple traps on one trap-arm.
Thank you sir!
I only see a 45 degree elbow going uphill on the disposal.
More pics on other computer will try to post pics of the other side later. 3 p-traps.
I would like to see more also.
I only had the one more and it wasn’t as good of a pic as I remember but here’s both side by side.
