I am hoping you can all give me some input,
- There was a GFCI in the bathroom, when I tried to test it with my pocket tester and with the test button on the GFCI, I got a beep out of the smoke detector in the hall but the outlet did not lose power…should I just write this up as “GFCI did not test correct” and mention that it is on the same circuit as the smoke detector.
- The home was going to be set up to have an apartment…this never happened. The home has electric baseboards throughout. The service was 125amp to the (what is now the main distribution) panel and in that panel there was a 60 amp breaker that went to the other (now the auxiliary) panel (100 amp)…so, this 1,400 sq ft bungalow had 125 amp service supplying the entire home. It seems a bit small to me but I cannot see it being a defect…am I right?
Any assistance would be appreciated.
Thank you
