Originally Posted By: jtedesco This post was automatically imported from our archived forum.
dbush wrote:
For our sparky's
Should you wire two bedrooms to the same AFCI breaker?
Should a non-bedroom be on an AFCI breaker?
Should you have a GFCI outlet on an AFCI breaker?
Thanks
1. I would not. Two bedrooms may already be supplied by the same branch circuit anyway, but it is with conventional wisdom that it is best to run more than one branch circuit to supply the outlets in bedrooms so that the rooms would not be left in total darkness.
2. I would, because fires start in other rooms too.
