Hi again, recommendations please for an air sampling pump for mold air samples using a Z5 or similar cassette.
Also any labs that accept samples from the uk.
Many thanks in advance
I use a Zefon pump which can use many different types of cartridge including the Z5. I have a plug in model, but wish now that I had purchased the battery operated compact model. If you can afford it go for it!
Ditto. Go for the battery operated one.
Thank you for your reply, I have just found a uk company for the Zeflon so hopefully will be all set up in 28 days time.
Really appreciate you taking the time to reply.
Kind Regards
Jon
I will look into this thank you
