Here is another fine deck 5 years old!!!
there is just no arguing with quality Buck…now just my personal opinion between you and me the guy that cut those stringers should have his power tool privileges taken away
Who wants to live with high voltage lines buzzing in the backyard, anyway? I’m convinced you could build a house 100’ from a sewage plant and someone would buy it.
Did I look at that wrong… or was a 2X used as a post?
Was 2X material attached on either side with nails only? Eee gads.
BTW… I’ve had to use hardware when stringers land like that here. Is that a req. there, or could they have pressure blocked? Just curious. We used to be able to pressure/shear block a lot of stuff… not so much anymore.
