See the dimpled membrane? See the edge of the basement floor, about 18" was busted out/replaced aka ‘new looking’ huh? Below i’ll post the sump pump.
QUESION… kind of important don’t you think???
Did the interior basement system and sump pump AND the contractor/company who installed it, did it STOP the water from where it’s still entering and did the contractor correctly identify where the water is still coming in? 3 videos of same leaky basement
If one doesn’t STOP the water from coming in then you’ll never stop/prevent mold, efflorescence etc.
Yeah yeah sure, maybe the contractor DID tell the homeowner the interior basement system will not stop the water from entering although that is NOT what Mark Anderson has seen repeatedly over 35+ years. Almost all are not honest with ANY homeowner and their leaky basement, nope. (yeah sure who knows, maybe the homeowner installed the crap himself)
BOTTOM line, the problems aka exterior cracks and open joints etc should have been waterproofed and backfilled correctly on the outside. The interior system should not have even been a moronic-thought as a solution, got that?
Idiots. Many of them too.
One more point on this-video for now, yeah… maybe if they’d have covered the entire foundation wall w/the stupid dimpled membrane it might have kept the water that is still coming in, off the floor. Point again is, it doesn’t stop mold etc and some homeowners think their leaky basement was solved if and when these nitwits DO cover most-all of the foundation wall with a dimpled membrane when they don’t see water on the floor as they did before. Fact is they were lied-to, bs’d and often it costs LESS to do exterior waterproofing of the lone leaky area!!
Video 2, https://www.youtube.com/watch?v=msCtmMdT0uk
he goes outside, says to “check drainage”. Another myth. Yeah yeah it doesn’t hurt to try and divert some surface water away but you’ll never keep all SUB surface water OFF the stupid foundation wall on longer heavier rains but go ahead and try, many do. POINT is, the actual problems are cracks, open joints etc on the exterior of the wall, NOT the drainage.
Video 3 https://www.youtube.com/watch?v=vRW0YSMektY
sump pump… some think the sump pump is part or all of their problem and-or every basement must have a sump pump, pffft, nope, just another myth.
IF this area was the homeowners only leaky area then they could have spent LESS on exterior waterproofing of this area which would have STOPPED the stupid water from where its entering.
Find the problem(s), sometimes it takes a little time and PATIENCE which in todays screwball world can be difficult to find eh, find the problem…fix the problem correctly, end of stupid problem
Not all crooks in this business are interior buttheads (most are), some will try and scam homeowners out of a lot of green with high exterior waterproofing bids like this snot tried to do to this 80+ yr old lady… if you listen closely and put down your crack pipe you should be able to hear her say $11,000
