Originally Posted By: rkulla This post was automatically imported from our archived forum.
When a battery backup is added to an existing sump discharge line, does the backup discharge line need a check valve of it’s own? In the home I inspected today the backup was T’d into the main line above the main check valve. I think without a check valve of its own it would allow back fill into the basket threw the battery backup. If the exterior line ever froze up it could possibly flood the basement. I think it needs it’s own check valve in this case.
Originally Posted By: rcooke This post was automatically imported from our archived forum.
rkulla wrote:
I talked to my local city inspector. He stated it's not code but would be a good idea.
My Directions called for a 3/16 hole above the check valve so the line drained after pump down so there was no water in the line to freeze.
You should have a check valve on both lines if you have a single discharge outside or the water can just go in a circle.
I am on town water so I put in a water powered sump pump cost about $60.00 no maintenance like a battery system
The only problem with a water powered unit is you have to be there to turn it on, much like a generator. It won’t do you any good if your not home to turn it on. Generators give you a false sense of security unless you have good neighbors that will go in your garage & fire it up for you when your out of town.
rkulla wrote:
The only problem with a water powered unit is you have to be there to turn it on, much like a generator. It won't do you any good if your not home to turn it on. Generators give you a false sense of security unless you have good neighbors that will go in your garage & fire it up for you when your out of town.
Wrong they have a float switch just like your electric sump pump does .
