Bearing?
Originally Posted By: cradan
http://www.nachi.org/bbsystem/usrimages/beambearing ]
Chris
http://www.inspect4me.com
Chicago Illinois Home Inspections
Originally Posted By: rcloyd
Good call Chris, I would have done the same.
Regards,
Russell G. Cloyd
Intra-Spec Home Inspections
& Code Consulting, LLC
859-586-4591
www.intra-spechomeinspections.com
Originally Posted By: R. Michael Gray, P.E.
You definitely did the right thing. This is the kind of arrangement could become unstable if anything shifts.
R. Michael Gray, PE
webmaster for www.houston-slab-foundations.info
Looks like they need some wider shims … icon_eek.gif … and the entire beam pocket should then be grouted solid. Good call.
Just my opinion and 2-nickels ...
Robert O'Connor, PE
Eagle Engineering ?
Eagle Eye Inspections ?
NACHI Education Committee
Never built a home myself, (and was NOT present when the foundation on this one was finished, and framing started), so I’m not quite sure how this happens. Look closely at the photo. The pocket looks like it was widened (to the left) to accept/accomodate the beam. Poor placement of shims aside, who do you think “measured once & cut twice” here? Foundation guy? Framer? All the way back to the design(er)/architect? Just curious as to what you may think…
Chris
Assuming this house is under construction, this is repairable and it should go back to the framer assuming he installed the beam in question. This is a defect that might not ever cause a problem, but it certainly could do so. It should not be that hard to fix. No competent carpenter would consider this work acceptable.
R. Michael Gray, PE
webmaster: www.houston-slab-foundations.info
to call-it-out. My thinking was that no one knows how this home will settle, and what those settlement dynamics might be.
Chris
Originally Posted By: ccoombs
In school we were testing a concrete beam. We used short steel I-beams between the slave piston and the concrete beam. They were set slightly off center (not intentional), very similar to the picture. During the test one of the I-beams shot out. I must have been weighed 25#. But it traveled across the room and took out a heavy work bench. If it weren’t for the bench, it would have taken off the leg of a student. A very powerful demonstration of eccentric loading!
Curtis
