Hello, I am currently taking the “How to Inspect the Exterior Course” My question is referring to Board-and-Batten Siding located in (wood siding) (Solid Wood or Lumber Siding). In the provided JPEG, I don’t understand what stops water from intruding through the seams between the battens and boards. Most other siding I’ve seen is akin to shingles in that water is guided onto the top of the following shingle. However in the diagram it seems it would just leak behind the siding unimpeded?
Look at what it says in parentheses. (Top view). Board and batten is run vertically. If the illustration was a side view, it will be difficult to see the spacing between the board and batten. It will look like two layers of continuous siding.
when run vertically, you’d need a decent wind to force water into the seam and into the gap. The water then touches that vertical gap/slot…and drains down and out. The housewrap/tar paper provides some water protection as well.
Oh my gosh I completely overlooked that, in the course it is talked about in sequence with many other diagrams all from the side view. Thank you.
