Licensees shall not characterize their inspection results in a home inspection report as representing a determination of compliance with Ohio Residential, Mechanical, Plumbing, or Electrical Codes, determining the existence of serious hazards as defined in OAC 4101:8-01, or recommending the method or process for remediation.
Sounds like no phase inspections for home inspectors?
Nope! Failed again. It’s pretty easy to perform a phase inspection without making any determination code compliance. It’s done hundreds of times every day.
I would, however, advise that YOU not perform phase inspections, pre-purchase inspections (new or resale), or any other type inspection other than that very narrowly defined function as an Ohio ESI, especially until you can at the very least demonstrate that you’re capable of passing that most basic CPI exam.
