Bosch Heat pump Tonnage
Does anyone know the tonnage of this Bosch heat pump (age is 2 years old)
DSCN2195 DSCN2297 DSCN2298 DSCN2299 DSCN2193
According to Bosch model number nomenclature 5 Ton.
The 60 in the model number is common in most manufacturer model number style as in 1.5 Ton would be 18, 2 Ton 24, etc.
12,000 BTU per ton = 60,000 BTU / 5 Ton nominal capacity
Looks like a 5 ton condensing unit, 4 ton A/C evaporator coil
You can take that to the bank. Scott is well versed in HVAC. :smile:
Yep! 60/12=5
