What is the tonnage of this new Heil package unit heat pump ? 3.5 or 2.0 ?
2 ton according to the model number. 5th and 6th number on model number for Heil.
http://productguide.goheil.com/media/6467976/residential-nomenclature-only.pdf
just a guess and without further research, I would say 3.5 based on the model # first 2 digits and the size of the unit. Of course I would research and verify before reporting it.
That’s why I said I do further research, not just based on my first guess lol!
Good question and makes you make sure you don’t shoot from the hip.
Good info Martin I do it the hard way.
PHJ424000KTP0A Cooling BTU 24,000 SEER 14.5, EER 11.5, Heating BTU 23,400 , HSPF 8.0
Yep, two ton is right on the $, Martin.
I would look at the size of the house and determine which would fit
PHJ4 (24000) KTP0A
There are 12,000 Btu’s per ton. The number (24) in the model number indicates the unit is 24,000 Btu’s, divided by 12,000 Btu’s per ton, equals (2) tons.
Big package unit. Mini split would do the same thing.
Thanks for the chart
