Is that blue color indicative of foundation insulation foamboard below grade. I know your area probably won’t have S/T activity like my area, but trapping moisture behind Vinyl and up to and/or behind the brick veneer and against wood structure is always trouble in our area.
Weepholes are required, installed more times than not, but AHJ typically won’t call’um on it if left out. On occassion, AHJ has made the Bldr.drill and install, but rarely. I will note in my report if exclued.
