Filled a jet tub yesterday. Water came out pretty brown. Sinks in the house a little brown as well. Filled the second tub, water still brown.
House has 1997 water heater, and water softener system. House has been vacant, heat on, water off for quite a few months.
Disclaimed the softener, but research online makes me think that it may be the source of the problem. I would have thought with all the water I used in the house any rust from the HWH would have been cleaned out.
The client contacted the Softener supplier. Unit upgraded in 2012.
Told the client to have a plumber in to see if they could ID the issue.
If it were mine, I’d close the bypass to separate out the softener and see if that makes a difference.
Just for sh*ts and giggles, and for the educational aspect, anyone have any ideas or knowledge to share. My expertise is not water softeners!
Did the toilets also have brown water .If yes you might want to look up Iron Bacteria .
I did a post on this a few years ago .Will try and find it … Roy
Sounds like city of Edmonton water to me. Let the water run for a while to flush everything out. There is some kind or light brown stuff in our water that Epcor says is OK but looks horrible. When I check a whirlpool bath that has not been used for a while there is always brown flakes everywhere when the jets are turned on. Older shower heads and faucets that have not been cleaned are coated with brown deposits, there may be brown rings at the water line in toilets that have not been used.
Vermilion is using Edmonton water now. They finished the pipe line about a year ago. The water seems fine but does have that brown shade you guys are talking about. I looked at a home last week and the water had been of for two weeks.
It took about 15 minutes for the water to start running clear (kind of). Every tap in the house ran brown on the hot or cold water.
I looked into it and found out that the city gets the water from the river. The river has shale which corrodes and gives the water a brown tinge. At least that is what the city said.
Could be Galvanised piping.
Here in High Springs city water it is chlorinated but not filtered… if a home has been vacant for month the water will smell like crap and with a brown tint.
However, If ran for a few hours it will clear up.
I call it swamp water.
