I ran across this at a job and wasn’t sure if this is proper. I am used to the metallic cable clamp Connectors. My concern is that it doesn’t provide a secure enough hold on the wire. But wanted to ask as well.
Thabks
I believe this is what you are seeing.
I think so too. I just wasn’t familiar with a rubber clamp like that. Just the cable clamp Connectors
Nothing wrong with putting two NM cables in one of those snap in plastic connectors as long as the cables are within the size range that is part of the connector listing.
Awesome! Thanks for the help!
Enclosure cable retention bushing.?
