I inspected a home today that was built in 1993 and was put together fairly well, but I did run in to this odd structural situation.
This girder cantilevers about 3’ past the pier and sits over a masonry fireplace. I am unsure if this was an oversight when built, but it appears someone noticed and tried to fix by applying some more blocks then gave up. The piers are placed every 6 feet.
I have noted it in my inspection with a recommendation for it to be fixed professionally, however I wanted another opinion. Would you recommend this to be repaired?
