What would you say about this? This is in a 42 year old home. I don’t see any floor settlement and the center one third of the floor joists is in the center one third of the bottom brick. Not sure what to say. Monitor or repair. Maybe have a GC assess and repair if necessary.
Skip,
Intermediate floor support is not as significant as other structural components, but needs to be professional. Therefore, I would describe this in my report, or include the picture, and recommend a second opinion.
Maybe not in this situation but, that thinking can get a person in trouble. Often, after overloading time and time again, structural failures are sudden and catastrophic.
I often remind people of Mount St, Helens when I hear “It’s been that way for years”.
I must be missing something: 42 years ago I’ll bet the pier was in the middle of the beam and the and all the blocks lined up. Looks like it has moved 3 inches to the right. How, who knows, but why put it in off center? Looks to me like it moved. Now it may be done moving but it looks like it moved or was moved.
Did you probe to determine if there was a footing? When I see someting like that I always try probing diagionally under the block - ocassionally, I find nothing but soil.
I think one would find that most likely there is no footing support under this stacked block pier.
I am guessing here, but looking at the picture and not knowing what part of the Country it is, I am seeing that their is no vapor barrier on the ground,
No insulation in the joist space, and the carrying beam is most likely made up of two members with a ledger on both sides with notched floor joist.
That would tell me this block pier is not carrying a tremendous amount of load.
I believe, from looking at the picture that the soil type appears to be of a high relative moisture content which is evident on the bottom block course and the wicking affect in appearance.
It would or could be conceivable that over the years, the clayish dirt settled and the bottom block shifted downward on one end about 30 degrees and the upper tiered blocks slide foward due to the incline.
When the obviouse sagging in the floor, someone went underneath and either jacked it up enough to pack dirt under the block and used what I am seeing as a brick to wedge it up.
So the original block went back to it’s original position, but was still too much pressure at the time to slide the upper ones back where they belong.
It’s hard to see from the picture exactly what the pier is carrying, but I see no mortar on the top of the extended end of the bottom block, and if there is mortar at all between it and the next block up, it doesn’t appear to be cracked, which kind of rules out the idea of lateral movement. So, the load path is direct from the beams to the ground, and therefore the offset in the blocks is of no consequence. As I said, unorthodox but acceptable. The suggestion that the earth be probed for presence of a footing, however, is a good one, but in that climate, maybe a footing isn’t required…that all depends on the load transmitted to the pier, and we cannot see enough to determine that.
I was just funnin, love your post. Folks in Maine are a hardy breed, dry sense of humor but a sense of humor.
Had moose poop mailed to me by a good Maine friend once, told me Io was his tourism marketing plan. See moose here! and sent me proof they where there…drank to many beers with him to be mad…never forgot it though…glad he is my friend…no tellin what that crazy Mainer would send me if he hated me!
I don’t know aparently there was some problem some time. It sure don’t look like it was there from the beginning. That beam looks like there two 4x4’s on the right and an 8x? 6x? on the left. Again, don’t look to me they are originall install. I’m woundering why the floor joist was notched at all. If those are 4x4’s and the joist are less than 24 inches deep that goes way beyond the recomended 1/6th max for a notch in a floor joist. Don’t it?
