Caulking in Kitchen and Bath
Originally Posted By: charper
Where does code state that caulking is required at seams in kitchens and baths, around sinks and at countertops in kitchens.? I thought I had seen it somewhere.
Charlie
www.HomeInspectionGa.com
Originally Posted By: bkelly2
Charles I do not know the code but if sinks, tubs, showers and countertop near sinks are not sealed properly, ie caulked, thet leak. And I always call out leaks.
“I used to be disgusted, Now I try to Be amused”-Elvis Costello
Originally Posted By: kdolin
I dont know about code but the two main real estate contracts here, specifically exclude caulking. However I still make note.
Same here, I always call out the lack of proper caulking. However this time on a NEW construction the builder says…“if it ain’t code” I ain’t fixing it. The buyer is an elderly woman who doesn’t want to cause any trouble.
Charlie
Quote:
A typical separation between the counter top and the backsplash should be grouted or caulked to forestall moisture intrusion.
Above is the language I use when water drips between the kitchen sink and countertop. When I perform a home inspection I am not that concerned with what does or does not get corrected ( life threating items excluded). If the builder will not fix it can't the buyer get a tube of silicone or DAP and do the job?
I do not know what you guys are talking about when you mention the real estate contract. Here realtors mention their contract/s specificaly that the selling agent is entitled to the inspection report and I agree with them, I do not give them a report but I agree, they sure are entitled. I then tell them I am not a party to their contract/s and continue on my way.
"I used to be disgusted, Now I try to Be amused"-Elvis Costello
Originally Posted By: mcyr
Charles;
Caulking in a new home or old is considered cosmetics in the older home and an aesthetic standard of practice in the newer homes which also holds protection from water leakage behind the counter and provide sanitary confidence by the owner that any water spillage will be confined to the counters and not behind the wall.
The codes do not spell out a standard of practice unfortunately, and it is left to the building Contractor to perform to the Standard of Practice for that Geographical Area.
Some Contractors are ethical and some not.
Some Contractors are conscious and some are not.
Some Contractors are fair and some are not.
Some Contractors are value giving and some are not.
Some Contractors are honest and some are not.
Marcel
Originally Posted By: escanlan
Quote:
P2705
INSTALLATION
P2705.1 General.
The installation of fixtures shall conform to the following:
3. Where fixtures come in contact with walls and floors, the contact area shall be watertight.
Manny (Emmanuel) Scanlan
Knowledge is power, but sharing knowledge brings peace!
Marcel good points. As I am sure you have seen a sink or two installed in your time, have you ever installed a sink without caulk, I know I have not. I believe that most sink installation instructions call out for caulk. Charles have them show you the manufacturers installation instructions.
escanlan wrote:
2003 IRC;
Quote:
P2705
INSTALLATION
P2705.1 General.
Excellent
rgallahorn wrote:
Try IRC P2705.1.3
P2705.1
General. The installation of fixtures shall conformto
the following:
3. Where fixtures come in contact with walls, the contact
area shall be water tight.
Opps, guess I'm too slow
More the merrier
Come on guys, caulking fixtures, code or not . Should not be even thought of as a code. Plumbers that don't caulk fixtures should be fired.
Marcel
Marcel,
I agree! The code reference is just to help force the point with the builder. Now that he has code references he can come up with a new excuse why he won't fix it! ![icon_rolleyes.gif](upload://iqxt7ABYC2TEBomNkCmZARIrQr6.gif)
Call it as you see it in your report and let the buyer deal with the seller.
What make logical ethical construction sense to some dose not mean anything to some.
Marcel
Originally Posted By: tschwalbe
First of all we dont inspect for code. second you are doing your customer a disservice if you dont call it out because it will lead to the destruction of the shower or countertops or what have you. Not to mention lead to mold growth.
You are very right…we do not inspect for code…But on the other hand this is a brand new home and I would expect the builder to do what is right. I will always call these problems out for the buyer because I think that is what they are paying me to do. I just wish that the "s#!t - know it all " builders would drop off the face of the earth. OOPS - I guess if that happened I would not have a job.
Charlie
I inspect to many codes, I just do not quote the code inspected to. ![icon_wink.gif](upload://ssT9V5t45yjlgXqiFRXL04eXtqw.gif)
This is a given we all should do this & if this is new construction the even if it was only cosmedic whic it is not you would still call it out.
If this is new construction than you should commenent on cosmedic items it is the only time you are allowed to. I do a lot of new construction and I have never had a builder say that he wouldnt caulk some thing that i called out. It takes 2 seconds to do that.
now on the other hand I do have a builder pissed off at me for calling out a inproper cermac tile installation This is going to cost him thousands of dollars to fix plus a 2 week delay in closeing. He should be mad at his contractor but if it hadnt been for me it would hsve slid by.
Originally Posted By: lewens
Charkie
The thing you have to say to any builder that gives you the " if it ain’t code I don’t fix it" thing is ask him if he is a minimum builder. Then explain that code is a bare minimum requirement. If he continues with the code nonsense tell him you will let it be known around that he is only interested in himself and his clients don’t matter. That will usually make them see the light.
Larry
Just my usual 12.5 cents
From The Great White North Eh?
NACHI-CAN
www.aciss-brant.com
www.certifiedadulttrainingservices.com/
I guess a conclusion for all these post would indicate the maybe the lowest bidder is not quite our best value for the job.
Usually the second highest is where all areas are covered as far as quality and performance.
Dose this sound like you get what you paid for?
Marcel
