Certified Drone Pilot Training Course
Chapter 12, Weather Theory:
Drones are a light weight machine that can be easily influenced be weather conditions. Performance of the craft can be effected by temperature, moisture, wind speed, and barometric pressure. When flying close to buildings or trees extra allowances should be taken into consideration for wind gusts and also changes in wind direction including up drafts and down drafts.
Hi! Just starting the course and wanted to introduce myself. Looking forward to getting started.
Ray
Very interested in how well this course will prepare me for FAA AKT… Ill let you know when I find out.
I appreciated how the class started with rules and regulations. I don’t have a drone yet but thought having a little more knowledge about using a drone would help me decide which drone would be best for me. I’ve been thinking about doing this for awhile, now being stuck at home with this pandemic, I have the time and am looking forward to what I’m about to learn.
I am interested in passing the drone pilot test. Has anyone successfully passed the test with this course? Thanks
Hello all,
I’m Joe from Michigan. Just wanted to introduce myself as I begin this course.
Starting the course!
Hello all. Here we go!
I am starting the Certified Drone Pilots Training Course. I want to be able to supplement my roof inspections with a drone not replace them.
I’m stuck on visual flight rules in section 2. When I click on the users Guide link, I’m confused as to what information I need to know and where to find it. I don’t see the a VFR Terms Tab.
Thanks,
Paul
I am located in the Hudson Valley, NYS. Does anyone know the testing locations for the AKT FAA Drone pilot license?
Since the Hudson Valley goes from NY City into the Adirondacks at Lake Tear of the Clouds, some 235 miles, not sure where to suggest. In the Albany area try Schenectady County Community College. They have a pilot training program. Also, the flight school at the Schenectady Airport. For other locations check local flight schools.
Has anyone used this course to study for the FAA certification exam? Is the course materials have prepared you enough, or would you recommend taking a course elsewhere?
Does anyone have suggestions regarding drones in Canada, specifically Ontario?
A member just sent in a great essay response! Check it out:
View Question
Research & Writing Essay Instructions
  1. Choose any chapter from https://www.faa.gov/regulations_policies/handbooks_manuals/aviation/phak/ that directly relates to the topcis covered in this course.
  2. Study the information that you chose.
  3. In the box below titled “Your Essay," write an essay that describes what you’ve learned from reading the article or studying the image.
Your essay must the following criteria:
  • It must be written in English.
  • It must be at least 40 words in length.
  • It must be written at a minimum 4th-grade level.
  • It must sufficiently comment upon the chosen article or illustration that is related to the main topics of this course.
This research and writing essay assignment is very similar to what a home inspector does during a home inspection--performing an inspection, researching, studying, making observations, evaluating, writing notes, formulating opinions, and communicating observations in written form.
Once you submit your essay, it will be posted to the InterNACHI Inspection Forum. If the essay does not meet the criteria, you'll be notified by email to rewrite the essay.
Please continue with the course after submitting your essay.
I read Chapter 12 Weather Theory and learned that convective currents can cause bumpy turbulent air that can be experienced when flying at low altitudes during warmer weather. Plowed ground, rocks, sand, and barren land absorb solar energy quickly and can therefore give off large amounts of heat. Water, trees, and other large areas of vegetation tend to absorb and give off heat slowly. Convective currents are particularly noticed in areas with large land masses next to large bodies of water such as oceans and lakes.
How long does it take to learn to fly a drone? About 4 accidents…
