Change to Standards of Practice
Originally Posted By: gromicko
2.7 H has been changed from:
H. A representative sampling of switches, receptacles, light fixtures, and ground circuit interrupters.
to read:
H. A representative sampling of switches, receptacles, light fixtures, and all ground circuit interrupters noticed.
http://www.nachi.org/sop.htm
Nick Gromicko
Founder
dues=79cents/day.
I much prefer email to private messages.
Originally Posted By: jpope
Makes perfect sense.
Jeff Pope
JPI Home Inspection Service
“At JPI, we’ll help you look better”
(661) 212-0738
Originally Posted By: Blaine Wiley
Sounds wimpy to me.
Originally Posted By: jstewart1
makes sense to me too
Originally Posted By: lschmid
For clarification: does it mean all GFCI’s or a sample of all noticed? I personally think all noticed should be checked.
Larry Schmid
First Choice Home Inspection,Inc.
South Carolina Chapter President
www.1stchoicehomeinspection.com
A SAFE HOME IS A HAPPY HOME
Originally Posted By: jhagarty
I thought that changes were handled by Committee.
http://www.nachi.org/sopcommittee.htm
Have they weighed in on this?
Joseph Hagarty
HouseMaster / Main Line, PA
[email protected]
www.householdinspector.com
Phone: 610-399-9864
Fax : 610-399-9865
HouseMaster. Home inspections. Done right.
Originally Posted By: dedwards
That doesn’t read right. Ive read it three or four times now and it still doesn’t read right. A sampling of “all” noticed? Im not smart enough to know exactly what that means
Originally Posted By: Nick Gromicko
We want all noticed GFCI’s to be checked. How would you word that?
Not all GFCI's. Not a sampling of GFCI's. but rather all GFCI's noticed.
Legal reasoning.
Nick Gromicko
Founder
dues=79cents/day.
All GFCI receptacles and circuit breakers found during the inspection.
Originally Posted By: rwills
All visible and readily accessible GFCI outlets will be tested. icon_idea.gif
Bob Wills - MAB Chairman
BW Inspection Services
Warminster, Pa.
http://www.bwinspections.com
That’s better.
Hold on, let me run it by counsel.
One of our guys just got in a pinch for missing a GFCI behind an appliance and in the past there has been a strong argument for testing all GFCI's so we're trying to correct both with one swipe.
Nick Gromicko
Founder
dues=79cents/day.
Originally Posted By: jpeck
"All GFCI protection found during the inspection is to be tested for operation."
Now, what happens when you test it and cannot find the reset?
"All GFCI protection found during the inspection is to be tested for operation with the GFCI's Test button."
Now, there is no risk of tripping another GFCI somewhere else off and not being able to find it.
Today the spa tub was protected by a GFCI "device" without a receptacle.
Regardless of what the GFCI protection is contained in (breaker, receptacle, device, whatever), the intent should be to test the GFCI "protection" for operation.
Jerry Peck
South Florida
Nope.
Can't use "readily accessible" because it could still be "readily accessible" without us noticing it.
Prefer not to use "found" as it implies that we have a duty to "find."
Hold on...
Nick Gromicko
Founder
dues=79cents/day.
Jerry, give me exact proposed wording. I’m sitting next to counsel.
Nick Gromicko
Founder
dues=79cents/day.
Quote:
Can't use "readily accessible" because it could still be "readily accessible without us noticing it.
That's why I put VISIBLE and Readily Accessible. A GFCI behind an appliance is not readily accessible as we are not required to move such items.
Warminster, Pa.
gromicko wrote:
Nope.
Hold on...
Where did "readily accessible" come from??
Okay, this eliminates the "found".
"All GFCI's inspected are to be tested for operation of the GFCI protection circuit with the GFCI's Test button."
Jerry Peck
South Florida
But how do we protect the inspector who does not notice a visible GFCI and so does not test it?
Nick Gromicko
Founder
dues=79cents/day.
Warminster, Pa.
Then he did not "inspect" it, and my wording includes all those he "inspects".
Jerry Peck
South Florida
Modify Blaine’s: “Test all GFCI receptacles and circuit breakers found during the inspection.” by changing “found” to “noticed” and add GFCI adjective in front of “circuit breakers” to read:
"test all GFCI receptacle and GFCI circuit breakers noticed during the inspection"
I have approval on this end.
Nick Gromicko
Founder
dues=79cents/day.
