I have had an amprobe INSP-3 for about 18 months. It is now giving me an internal fault error. What if any tool do you all recommend for circuit testing?
suretest 61-165
have an xtra if interested in purchasing
email @ website contact or call me
That is a good tool Barry has and he is fair. If I needed one, I’d go for it. ![]()
Knopp K-60
I have a sure test (older model) I rarely get out. In fact I rarely get out the K60, it is seldom needed. If yu want to get into trouble “over-reporting,” knock yourself out. Consider this post from '08: Problems with Ideal SureTest Circuit Analyzer #61-165
Extech CT70 AC Circuit Load Tester. I have both CT70 and CT80 with AFCI. Good circuit go to equipment. InterNACHI InspectionTools have great price.
Wiggles are great as well.
What kind of testing? A Wiggy®️ is all you need for doing home inspections.
Circuit Load Testings.
AC Load Tester
Selectable loads of 12, 15 and 20 Amps.
Measures loaded and unloaded AC Line Voltage.
Calculates and displays % Voltage Drop and Line Impedance.
Displays Peak Line Voltage and Frequency.
• Outlet Tester functions:
Neutral to Ground Voltage.
Hot, Neutral and Ground Impedance.
GFCI Trip Time.
GFCI Trip Current.
Open or Reversed wiring.
I concur. Bump. Problems with Ideal SureTest Circuit Analyzer #61-165
None for a visual home inspection. Now if you are doing electrical testing it depends on what you are trying to verify.
The things I primarily test and report on are GFCI/AFCI function, bootleg grounds, and proper wiring. I do not generally report voltage drop unless it is extremely excessive.
How do you test for bootleg ground?
Good question, Simon.
The neutral conductor is not a source to ground equipment. The neutral circuit conductor is the desired current return. All there is to a circuit, hot and neutral return.
Ground is a safety device only.
I know what it is and how to test for it, I was asking how @sbrinson does it. Thanks for your input.
This is the way it use to be tested…
That reminds me of my daughter when she was 3, or so.
She came running out of the bedroom shouting “Dad, Dad, there is fire shooting out of the wall”…while she had a toy metal knife in her hand. ![]()
And I had her show me where the “fire” was coming out of the “wall”.
It was soon thereafter that I took her outside near dark, because she had seen my Colt 1911, and put ear muffs on her and me and fired it off.
She never went near it again until when she was older and we took a class together on firearm safety.
Where did you find a picture of me?
On the unwanted children’s hot line…
I’ll confess, I did it twice. First time I stuck an antenna into 220V single phase receptacle, the second time I connected a wire between 2 nails and stuck them into a receptacle because apparently the first time I didn’t learn from the experiment. I’m probably lucky to be here to enjoy your grace, @rlewis5
LOL! LOL! LOL!
The ground impedance will be high on a bootleg ground. With a true round it should be very close to zero.
